Recently installed new DigiRig Mobile with FT857D cables. Have an FC-30 tuner installed, that requires using the rear CAT jack. Wired and tested an adapter similar to IZ0INX mod to send RX D, TX D and GND through the MIC input using and RJ45 plug with FT857D MENU MODE 59 (MIC SEL) set to CAT and an 8-pin DIN plug to receive the DigiRig CAT cable.
Eveything works fine using WSJT-X in FT8 mode. Worked CO8LY from Atlanta on 20M this evening:
ADIF Export
<adif_ver:5>3.1.1
<created_timestamp:15>20250204 022333
<programid:6>WSJT-X
<programversion:5>2.6.1
<eoh>
<call:5>CO8LY <gridsquare:4>FL20 <mode:3>FT8 <rst_sent:3>+00 <rst_rcvd:3>-17 <qso_date:8>20250204 <time_on:6>021445 <qso_date_off:8>20250204 <time_off:6>021545 <band:3>20m <freq:9>14.075150 <station_callsign:5>KO4WX <my_gridsquare:6>EM73UT <tx_pwr:2>10 <comment:14>First FT8 QSO! <operator:4>Mike <eor>
So I know I have the DigiRig to FT857D wired correctly.
Following the Config Instructions for Yaesu FT-857 and Winlink, Installed Winlink Express and VARA HF (unpaid for now), and configured, then did Open Session per instructions. The FT857D immediately goes into transmit with NO ALC. If I close VARA HF, the radio stays in transmit and the only way I can kill it is to shut the rig off.
Wondering if there is something wrong I’ve done in the config, but I think I have it set up correctly. At least I know the hardware and Windoze 11 configs are right since I can do FT8. Here is the log from RMS Express of the most recent Open Session attempt. This doesn’t look right, but I know nothing about troubleshooting Winlink/VARA HF…
2025/02/04 00:09:07 1.7.21.0 PTT Off. PTTport = FT-857
2025/02/04 00:09:07 1.7.21.0 bin->Radio 00,00,00,00,88 (PTT off)
2025/02/04 00:09:08 1.7.21.0 Vara HF WL2K *** Launching VARA TNC
2025/02/04 00:09:09 1.7.21.0 Vara HF WL2K *** Successfully connected to VARA TNC at 127.0.0.1 port 8300
2025/02/04 00:09:11 1.7.21.0 Vara HF WL2K *** Maximum signal bandwidth is set to 2300 Hz.
2025/02/04 00:09:11 1.7.21.0 Initializing radio for Vara session.
2025/02/04 00:09:11 1.7.21.0 Radio model = Yaesu FT-857, PTT port = FT-857
2025/02/04 00:09:11 1.7.21.0 Digital data mode = False, Internal soundcard = False
2025/02/04 00:09:11 1.7.21.0 PTT Off. PTTport = FT-857
2025/02/04 00:09:11 1.7.21.0 bin->Radio 00,00,00,00,88 (PTT off)
2025/02/04 00:09:11 1.7.21.0 Successfully opened radio control port COM3
2025/02/04 00:09:11 1.7.21.0 Save radio state. Model = Yaesu FT-857
2025/02/04 00:09:11 1.7.21.0 Save audio mux setting
2025/02/04 00:09:11 1.7.21.0 Finished saving radio state
2025/02/04 00:09:11 1.7.21.0 Set radio dial frequency = 3589.500
2025/02/04 00:09:11 1.7.21.0 hybrid->Radio 01,00,00,00,07 (Select upper sideband non-digital)
2025/02/04 00:09:11 1.7.21.0 hybrid->Radio 00,00,00,00,82 (Turn off split)
2025/02/04 00:09:11 1.7.21.0 hybrid->Radio 00,35,89,50,01 (Set frequency)
2025/02/04 00:09:11 1.7.21.0 Set data MOD connector to ACC (external modulation)
2025/02/04 00:09:11 1.7.21.0 Vara HF WL2K *** Using Yaesu FT-857, COM3, 4800 baud
2025/02/04 00:09:11 1.7.21.0 Vara HF WL2K *** Ready
2025/02/04 00:09:52 1.7.21.0 Vara HF WL2K *** Closing
2025/02/04 00:09:55 1.7.21.0 PTT Off. PTTport = FT-857
2025/02/04 00:09:55 1.7.21.0 bin->Radio 00,00,00,00,88 (PTT off)
2025/02/04 00:09:55 1.7.21.0 Restore radio state. Model = Yaesu FT-857
2025/02/04 00:09:55 1.7.21.0 Finished restoring radio state
2025/02/04 00:09:55 1.7.21.0 Successfully closed radio control port COM3
2025/02/04 00:59:46 1.7.21.0 ---- Winlink Express is closing ----
and here is the VARA.INI contents:
[Soundcard]
Input Device Name=DigiRig_In (USB Audio Device)
Output Device Name=DigiRig_Out (USB Audio Device)
ALC Drive Level=-5
RA-Board Device Path=
Channel=0
[PTT]
Rig=52
PTTPort=COM1
CATPort=COM1
Baud=4800
Pin=1
RTS=0
DTR=0
Via=3
Icom Address=
[Setup]
Registration Code=
Registration Code 1=
Registration Code 2=
Registration Code 3=
Callsign Licence 0=
Callsign Licence 1=
Callsign Licence 2=
Callsign Licence 3=
WaterFall=1
TCP Command Port=8300
Retries=15
View=1
CW ID=0
RA-Board PTT=0
Compatibility=0
Updates=1
ATU=0
Encryption=0
Password encryption=MyPass
Enable KISS=0
KISS Port=8100
[Monitor]
Monitor Mode=0
[Log]
Log Caption=Log*
Enable SysLog=0
SysLog Host=localhost
SysLog UDP Port=514
CommandsLog=0
SysLog Station Name=
[Position]
Top Position=6900
Left Position=14325
Appreciate any help for a wayward ham… Thanks!
73 DE MIKE, KO4WX
