Digirig mobile input attenuator
The audio from my FT-817 is too high and cannot be adjusted lower using the regular level controls. I took apart my digirig mobile to see if I could cut the trace between the ATT pads, but I do not see a trace. Does it come precut or do I just not see the trace?
The trace is hidden under the black coating.
No, the trace is just covered with the black solder mask like the rest of the copper that is not intended for soldering. Cut away!
That worked!
Thanks very much
VE7IGH
