The drivers below, and directions are based on Windows 10/11… There is more than one way to skin a cat in Windows; this is the manual way, as I find the update driver via Device Manager does not always find the most current driver.
Disconnect the DigiRig from the USB cable (If you have Device Manager open, the Silicon Labs with the exclamation mark notation under Other Devices, should disappear);
From your web browser, download this file link previously listed by @Constrainted, into your Download (or directory of your choice, but I’ll use Download in this example) Directory:
https://www.silabs.com/documents/public/software/CP210x_Universal_Windows_Driver.zip
Open your Download directory either from your web browser menu, or Windows Explorer and locate the CP210x_Universal_Windows_Driver.zip file;
Right click on the CP210x_Universal_Windows_Driver.zip file, and select Extract All;
Leave the suggested directory location in the pop-up, which will be the same directory that you’re already in, and check Show Extracted Files When Complete if it’s not already checked, then click Extract;
You should see 6 files (UpdateParameters, CP210x_Universal_Windows_Driver_Release (You should read this file as an FYI plus install details), 2 of silabser, SLAB_Licence_Agreement_VCP_Windows, and UpdateParam), and 4 directories (x64, x86, arm, arm64);
Right click silabser.inf (it’ll be the one with the gear in the icon);
Select Install from the pop-up;
You will see a security warning, asking if you want to open this file - Select Open;
If you are not logged into your Administrator Account (you should normally be in a User Account as it’s harder to wreck things by accident, plus better for security of the computer), a pop-up will ask for your Administrator PIN - enter it;
After a moment you should get a pop-up that says, The Operation was Completed Successfully; then
- Plug the USB back into the DigiRig and the driver should install, and you’ll see the Silicon Labs CP210x USB to UART Bridge (COM X) show up under Ports (COM & LPT) in the Device Manager, no longer under Other Devices.
If that doesn’t work let me know.
Steve VE7IIF
