Digirig setting on FT897D for VaraFM. I’m using successfully a SignaLink and want to switch to my new Digirig and having problems with settings. Ed / K8EAF
Your transceiver settings are likely to remain the same while switching to Digirig.
The difference is that in software configuration you want to setup CAT control and PTT method is by RTS. For other information on FT-797D, please check out these posts.
