The tight connection is not normal. Please make sure you plug 6 pin connector (one with the little plastic tab) into the matching 6 pin port (one adjacent to the USB connector). Please also inspect the connector to make sure none of the pins are bent out of shape.
More info on connecting and configuring FT-891 can be found in this post:
