FT891 and WSJT-X receive levels
I am using the Digrig 891 with the FT-891. I am using WsJT-x version 2.6.1
The signal coming in from the radio can be heard if I listen to the input.
In WSJT-X, the receive signal meter continuously bounces. I have not been about to have a constant level of signal. Also, I do not think I am decoding all the signals I am hearing.
What have I done:
ACG on and off
I increased the Data Data setting in the 891 to get more of the signal to show.
I lowered the Data Data setting in the 891 to ensure it was not overpowering, but the meter never maxed out.
Heavy-duty USB3 cable
Ferrites on and off the cable.
I moved from the signalink to the Digirig. I’ve never had issues like this before.
What am I missing?
Thanks for the suggestions.
W3AND
Let’s see how your waterfall looks like in WSJT-X.
This will give some idea if audio is making it there alright.
Please see Windows 10 Not Seeing Digirig - #4 by KG4LAC
Windows 10/11 are the same in this situation.
Attached are two Screenshots of the waterfall.
I also included the WSJT-x
One thing I want to remind you. It is not that I am not making any contacts. I made 35 the day of these screenshots. You can even see the receiving meter is showing 0 after a high of 60.
It looks like radio may not be holding frequency or something else at play here.
Those transmit blocks by other stations should be sharply contained within 50Hz each.
The band is fading, but this is how waterfall looks on my IC-7300 right now:
Let’s take Digirig out of equation by trying the acoustic coupling. Can you adjust WSJT-X to take audio from your computer’s mic and put it close to radio’s speaker. Do you get a sharper waterfall this way? You’ll need to listen to fairly loud FT8 chorus for some time while keeping ambient sounds low.
Clean up the WSJT-X Wide Graph.
Bins/Pixel 5. Start 200 Hz. N Avg 2. Spec 25%
FT-891 settings for digital mode
05-06 CAT RATE 38400bps ← Default 4800bps
05-07 CAT TOT 100msec ← Default 10msec
05-08 CAT RTS DISABLE ← Default ENABLE
07-12 PC KEYING OFF ← Default
08-01 DATA MODE OTHERS ← Default PSK
08-03 OTHER DISP 1500Hz ← Default 0Hz
08-04 OTHER SHIFT 1500Hz ← Default 0Hz
08-05 DATA LCUT FREQ OFF ← Default 300Hz
08-07 DATA HCUT FREQ OFF ← Default 3000Hz
08-09 DATA IN SELECT REAR ← Default
08-10 DATA PTT SELECT DAKY ← Default
08-12 DATA BFO USB ← Default LSB
16-03 HF PWR 40 ← Default 100
16-10 DATA MIC GAIN 35 ← Default 50
16-14 DATA DATA GAIN 50 ← Default 50
Press the F key momentarily to step through the Setting Modes as follows
Function-1 → Function-2> CW Setting
Function-1
WDH WIDEST < Widest = 3000Hz
IPO OFF ← Default
NCH OFF ← Default
Function-2
AGC OFF
DNR OFF ← Default
DNF OFF ← Default
CNT OFF ← Default
Denis,
I did as you said and there was no difference. This screenshot is both Digirig and acoustic coupling
Then I went through the mic settings in Window’s
I found something I had not seen before. Enable Audio Enhancement under the Advanced tab. I unchecked it, and everything worked.
Thanks for everyone’s help.
W3AND
Thanks for the update. Glad to hear you got it sorted out. Typically Audio Enhancement is turned off by default so it doesn’t get in the way very often.
I had the exact same problem and thanks to your post my problem is fixed also. Strange thing is I was sure I had unchecked the enhancements box but perhaps it wasn’t saved. Anyway, thank you thank you thank you!! 73’s
I joined this forum just to thank you all for this suggestion. The waterfall was appearing extremely faint, no clear 5hz bands, and the db meter was barely registering. Any decodes would respond with very strong signal reports, so figured it was something on the audio path into the laptop.
And sure was it!
Anyway, I found a checkbox that got turned on in Windows 11 audio settings.
System>sound>more audio settings then “recording” tab → double click Microphone on the list → Advanced Tab" → UNCHECK “Enable Audio Enhancements”
AND make sure Microphone on “levels” tab is also up to 100
Unchecking this (and hitting save, then restarting everything) and the band literally instantly came alive. Waterfall lit up like Christmas, looking like I expected. 20 decodes per inning. dB up to 80.
And QSOs are coming in.
Anyway, don’t be like me trying to diagnose antenna issues and cleaning my tuner bandswitch contacts when it’s a windows checkbox!
