I had everything configured a few months ago, then I put everything in storage.
I pull the radio out, set everything up, and now every time I try to send a CQ/Heartbeat/Test PTT, it switches from data mode to single side band
Any tips?
Any tips?
I’m not familiar enough with FT-891 to know what is the difference. Technically the data modes are using SSB, but let’s try to figure this out.
Do you have both Digirig’s audio cable and direct USB cable from radio to computer connected?
Nothing should be connected to Digirig’s serial port while using FT-891
I’ve tried both. Same result but currently from the digis audio port to the computer
If you are only using Digirig’s audio cable, but not radio’s direct USB cable then select rig=NONE in the CAT configuration section. In every case PTT method should be RTS pointing to Digirig’s COM port.
More information including configuration examples can be found in this discussion:
Have you found a solution to your ft891 switching between data and USB?
the mode in js8call was set to usb (looking at the screen shots)
the mode should be set to none if you want the radio to stay in whatever mode it was in.
you could also select data/pkt, in js8call if the radio supports that remote control command.
mine do not
