What would be the best cable for this rig for VARA? I am supposing the one with the Serial port connector on it?
But if you have an opinion, let me know.
WA6JFK
WA6JFK
Brian,
Check please out this TS-570 discussions
https://forum.digirig.net/tag/kenwood-ts-570d
and this one specifically:
Ok you show 2 cables for Kenwood HF, what one should I get to try out with HF VARA?
The kit includes both cables. 13 pin cable will give you the required functionality (audio + PTT). It is worth also trying DB9 cable to see if you can make optional serial CAT control working better than it was in my attempt.
