Proper cables for Icom IC-910H
Excited to get the Digirig Mobile on the air…the site referred to a set of cables for the IC-706 which included CI-V serial cable and another cable with a 13-pin DIN which the IC-910 does not use.
Searching the site again I found reference to a cable set Yaesu FT-8xx including a mini 6 DIN and a Mini 8 Din and specifically lists the IC-910 as being compatible with this cable set.
Has anyone had experience interfacing to said Icom transceiver?
I am hoping to not order the wrong items again.
Any/all help is appreciated
John
@John_Klewer I do not own this radio, but I did not want your post to go unanswered. In case you have not seen it already, Denis K0TX has posted some information about this radio in this forum.
Thank you
John
