Which Digirig do I need
I have two questions. First, I have an Icom IC-2820H which Digirig mobile do I need, CV-I or logic Level.
Second, Which Digirig mobile do I need for Yeasu FT-891, Logic Level or CV-i. I have two Digirig mobiles one of each. If I do not need the new Digirig for 891 that would be great. Please help.
Thank You
David
Hi @K5DLD:
Between the radios’ owner’s manuals and this link, plus the Additional Resources on the same page, you should be able to find the answer:
Selecting Digirig Mobile Serial Configuration – digirig
The signaling levels only come into play if you’re going to use the Serial cable. If you’re just using Audio (which can also do PTT BTW), the signaling levels do not matter.
All the best,
Steve VE7IIF
According to this post from Denis @K0TX, it does not matter:
As far as using Digirig Mobile (any configuration) with FT-891, please refer to this post for connections and configuration info:
Any success?
