The TM-281 has an RJ-45 microphone jack. Will DigiRig make a cable for this model?
From what I see RJ-45 cable from the store should work for your Kenwood.
Please post your results if you decide to give it a try.
Although the cable looks similar to the Kenwood, the pinout between the Icom radios and Kenwood are different.
Icom
Pin 1 = Red wire
Pin 2 = (up/down)
Pin 3 = (audio out)
Pin 4 = (PTT)
Pin 5 = Copper shield (bare copper wire)
Pin 6 = White wire
Pin 7 = Black wire
Pin 8 = No connection
Kenwood
Pin 1 = Keypad serial data
Pin 2 = N/C
Pin 3 = Mic (600 ohm)
Pin 4 = Mic Grnd
Pin 5 = PTT
Pin 6 = PTT Grnd
Pin 7 = 8V
If the pinouts donβt line up you may need to homebrew the cable from scratch or use one of the existing cables and re-crimp RJ-45 connector to match the pinout.
I wonder if this ever worked. When I shorten PTT Ground and Mic Ground, I donβt get any audio if I leave PTT ground connected to a sleeve - audio is fine, but there is a static noise. Also, PTT is always on, perhaps some resistance problem.
Works with static buzz, but no PTT
RJ-45 pin 3 (GND) β 3.5mm TRRS sleeve (GND)
RJ-45 pin 4 (PTT) β 3.5mm TRRS ring 2 (RIG_PTT)
RJ-45 pin 6 (MIC) β 3.5mm TRRS ring 1 (RIG_AFIN)
Audio disappears with PIN 5 connected to the ground, PTT is always on
RJ-45 pin 5 (GND) β 3.5mm TRRS sleeve (GND)
aha⦠rookie mistake, the pinout is on the socket not the connector.
