I bought a CI-V Digirig Mobile a while back and only recently tried WSJT-X. I’m facing difficulties in trying to make my ICOM IC-7000 work with it, mainly because WSJT-X only displays vertical line, similar to this issue.
Thanks for the suggestion! I did try it with a shorter USB cable in the hope of avoiding potential noise, I’ll try it if for some reason it isn’t fixed after the service.
Good luck. It’s more important than you may think. I thought mine was jacked up and wrapped a ferrite on a plain USB as a last resort I have since gotten one of these
Heading up to Payson AZ as Scout Camp comissioner in 2 weeks. Want to take up my IC-7000 for HF work on digital modes. Anyone have a good drawing of components needed. Linux hacker since 90’s so planning on raspberry PI solution with DigiRig.
Already got the shielded USB cable in my amazon cart. will order the rest this week.
Just received the new unit and it does not have line issues anymore. Thank you for the excellent service!
I also tried comparing it by using ferrite-wrapped USB cable and so far it seem to perform equally well compared to a regular cable. However, just to be safe, I’ll keep using the ferrite-wrapped USB cable for now.
