I’ll just drop this here. I came on this thread since my 891 stopped showing any modulation on the ALC meter between last night when I stopped and this morning when I started up again. Turned out for me to be that I had my system audio muted. Hoping that helps someone else.
I am having the same problem ALC 100%, No Power Out. I went to the G90 Settings with FT8.pdf, and verified all my settings match this, except I have the mode setup to U-D instead of USB. Receive works fine. I have tried adjusting all the level settings, but I still have no output.
edit: I show output on the Digirig - Speaker output in Windows Control Panel, but it does not appear to be getting to the radio.
@KB5RSM
i’m sure one of the moderators will split your post off to a new topic.
that should get you the most/best replies.
in any event, are you running flrig in the ‘chain’ as the OP was?
you certainly have the correct setting of U-D since that sends rx/tx to the rear acc port.
you mentioned the ft8.pdf, i don’t have that but i’m guessing it got you to the setting for audio input gain on the radio itself.
you might try cranking that up a bit just to get some output from the radio.
i’m also guessing you’ve probably checked the rf output 20 times by now to make sure it’s at 20w.
lastly, can you plug some earbuds into the digirig audio port and listen if you get audio out from the digirig? (when pressing ‘tune’ in wsjt-x)
i had to pick left audio in wsjt-x to get some ‘tone’ out of the digirig on one of my setups.
you might give the ‘audio’ tab a look in wsjt-x and try that.
A post was merged into an existing topic: Xiegu G90+digirig Mobile+flrig+WSJT-X = No Output at Radio
