Yaesu FT-450D setup issues
I’m having an issue with my 450D and a new v 1.9 digirig. The serial connection just doesn’t work. If I use identical settings with another serial adapter it works fine.
The audio is also not good on my new digirig, it much worse than an older v 1.5 I’ve been using (see attached screenshots form WSJT-X). These were taken with the 1.5 at 10% audio gain and the v 1.9 at 100% audio gain.
I almost think I got a bad sample.
Digirig 1.5 - clean audio, lots of FT8 decodes:
Digirig 1.9 - garbage audio, lots of birdies, almost no FT8 decodes:
This could be a cable issue, something like floating ground. Do you use rev 1.5 cables (TRS) with your rev 1.9 Digirig (TRRS)?
For the 1.5 I made my own cable. For the 1.9 I used new cables purchased with the digirig.
:warning: EDIT: Originally this message contained an incorrect pinout for the serial cable with pins 2 & 3 reversed as discussed below. The cable had to be replaced for OP to get serial CAT working. To avoid the propagation of incorrect pinout, this image was later updated with the correct schematic.
Re. audio: FT-450 uses 6 pin mini din. Please check the continuity to make sure cable has no issues.
For CAT control, it’s DB9 cable with straight pinout.
Let me know the results of the pinout test and we’ll take it from there.
So I got some weird results for the audio cable:
  • Tip - continuity to Pin 3
  • Ring 1 - Pin 2
  • Ring 2 - Pin 4
  • Sleeve - Pin 1 okay but No continuity with Shield
    This would make sense that the audio isn’t any good, the radio Audio Out isn’t even connected. Not sure how I’m getting any signal at all.
The serial cable is wired as you have shown, however, after looking at the manual for the 450D I wonder if this is correct for this radio. In the manual it has Serial Pin 2 as Serial OUT and Pin 3 as Serial IN. You have Pin 2 labeled as Rig RX, wouldn’t that be Serial IN which is Pin 3? I have a null modem adapter at work that I can try and see if that fixes the issue. Not sure if you sell more than one configuration of this cable, but this may just be the wrong version.
See attached screenshot from the manual.
I’m going to put together a test cable to see if the audio issue resolves. I’ll let you know later this week.
Thanks.
Joe,
Sleeve of TRRS should be connected to pin 5, not 1. Please make sure you account for solder side vs pins side perspective. Here is pin numbering from the outside:
Ground (5) is leftmost while wide side is at the top.
This cable is for CAT only and has no effect on audio. Audio cable is the one with miniDin6 connector on the other side. Did you have a chance to test the pinout there?
Let me rephrase for clarity.
I tested the Mini-DIN AUDIO CABLE with the following results:
  • Tip - continuity to Pin 3, NOT Pin 6 as shown on your drawing
  • Ring 1 - continuity to Pin 2, OK
  • Ring 2 - continuity to Pin 4, OK
  • Sleeve - continuity to Pin 1, but NOT with shell of Mini-DIN
This result leaves me to believe the reason my audio is bad is because radio Audio Out (Pin 6) isn’t even connected. Not sure how I’m getting any signal at all. I’m going to put together a test cable to see if the audio issue resolves. I’ll let you know later this week. This may just be an improperly assembled cable.
I tested the SERIAL CABLE with the following results:
  • Tip - Pin 2, OK
  • Ring 1 - Pin 3, OK
  • Sleeve - Pin 5, OK
  • Pins 7 & 8 shorted - OK
After looking at the manual for the 450D I wonder if this is correct for this radio. In the manual it has Serial Pin 2 as Serial OUT and Pin 3 as Serial IN. You have Pin 2 labeled as Rig RX, should that be connected to the Radio’s Serial RX Port or the TX Port? I wonder if the RX & TX are swapped and shouldn’t be in this case. I’ll experiment a little and see if I can get it to connect.
Thank you for the additional info.
Yes, it the serial pinout is reversed.
Re audio cable: you have a 9600 baud cable. Looking at the manual, it doesn’t appear that this model supports this pinout like most of other Yaesu transceivers using the same connector. You’ll need 1200 baud pinout from FT-8xx kit.
I’ll have both cables replaced. Arrangements in PM.
Just wanted to post that the replacement cables work perfectly. I have proper audio and rig control.
Thanks.
I recently purchased the Kenwood TS-480 cords for Digirig Mobile for my Yaesu FT-450D and I believe I’m experiencing the same issues as the OP. Serial connector does not allow me to connect thru any rig control software.
When I test for continuity for the audio cable I get:
Tip to Data Out - OK
Ring 1 to Data In - OK
Ring 2 to PTT - OK
Sleeve to Ground - OK
When I test for continuity for the serial cable I get:
Tip to Pin 3 - OK
Ring 1 to Pin 2 - OK
Sleeve to Pin 5 - OK
Pins 7 and 8 shorted - OK
Just as concluded earlier, I suspect that the serial output is reversed, and as you mentioned K0TX, I may need the 1200 baud pinout from the FT-8xx kit. Can you advise? Could I send mine in for a swap? Thank you.
PS - I purchased my digirig mobile in Jan of 2023.
Screenshot 2024-04-22 135831
I can’t get my digirig with ft-450d and wsjt to work. here’s the error message I receive.
This looks like computer and radio are talking initially.
Did you pass CAT test when you first setup WSJT-X?
I have been using WSJTX and FT8 for years with a Signallink. I switched to DigiRig because I was told it was faster with VARA. I went back to signalink and it works fine.
The CAT options with Signalink are limited to either not having it at all or using a separate device for it. You can certainly fall back to that level of functionality with Digirig as well while still enjoying a better PTT method.
So I guess I just don’t plug in the CAT cable, is that correct? The DigiRig will function fine with FT-8? I’ll give it another try tomorrow. I guess I’ll just have to stumble around and find what settings work.
Yes, the serial side is optional. You can operate with just Digirig’s audio and PTT by RTS.
Feel free to share the screenshots of the configuration and I’ll suggest the corrections if needed.
Signalink uses VOX for PTT. With Digirig most users use serial COM port for PTT which is predictable regardless of audio level.
Picking this thread back up to see if anyone might be able to suggest a fix for my setup issues on the FT-450D.
Purchased a DigiRig RS-232 with which I have successfully achieved CAT control of the rig, including PPT using the 1.6+ DB9 cable. I am using the 1200-baud audio cable from the Kenwood TM-V71A Digirig Cable Set.
The set up also successfully decodes audio when using a PC and when using a DigiPi. The issue I have encountered is in putting out transmitted audio. No matter the audio levels in software - Windows or ALSA mixer and the individual program - I am unable to achieve any power output from the rig.
I was quite sure when studying the wiring diagrams of both cables that their pin outs were identical. Did I miss something in that process?
Prior to installing the DigiRig at my station the rig worked well using VOX and a SignaLink USB so I am quite sure the issue is not with the rig.
Hoping this groups wisdom will help me trouble shoot the issue.
Thanks and 73 de VA2BKW
You can confirm the presence of the signal at Digirig’s output by plugging regular headphones into the audio socket as demonstrated here:
